Hi, when I use the Property1D object kit, I’m getting the “Cannot convert System.String to Speckle.Core.Model.Base” error. Please see the attached snapshot. Could there be a bug in this kit?
@connor @teocomi
I think the panels might be converting the output of some nodes to string, can you pass the material and profile directly instead?
Yes indeed, direct pass works. Thanks!
