Project Information missing in Power BI
Hi Speckle Team! :slight_smile:
We have been working on a power BI Template which brings the information from our Speckle Model (Source: Revit), and we realized that we can see the Project Information and the respective values in the model within speckle, but the same information is missing in the Power BI Query/Properties.
(Properties/Project Information in Speckle)
Do you know what can be the reason for this?
Looking forward to your feedback,
Best,
Raquel Mirra Santos
CC: @AlexHofbeck @ltascheva
Hi @rmsantos,
If you can view the data on the web app, you should also be able to access it on Power BI. You can apply a “Text Contains” filter on the speckle_type of the received data. I have tested this with Revit model data and it worked on my end. However, if it doesn’t work for you, please let me know and share the Model URL with me so I can try to reproduce the issue on my end and help you out.
Hi @gokermu !
Thanks a lot for the support! Was able to get all the project information with your solution :slight_smile:
Best,
Raquel Mirra Santos
