Problems with Revit > Speckle > Unity
Hi! This is my first time using Speckle. I am interested in the Revit-Rhino-Unity Interactivity and I was particularly testing the Revit to Untiy Streaming. I was able to stream my model from Revit to Unity and the mode showed up with a decent amount of resolution in Speckle(although it still seemed broken). When I receive it from Unity, however, the main geometry as part of the 3d model isn’t being received. Is there a workaround for this? Please let me know. Thanks. :slight_smile:
Hi @Yashwanth_M
If it’s possible, please could you add me to your stream, so I can test your geometry on my end.
