Hello, I am having trouble using the Rhino Connector 2.5.1 with Rhino 7 (free trial version).
When I try to connect to a stream from Rhino, I get a “could not get streams” message (first image below), and when I try to manually search for the stream with its URL I get a “something went wrong” message (second image below). The stream works perfectly fine when I access it from a browser (third image below), and works perfectly fine with the Revit connector 2.5.2 for Revit 2022 (fourth image below)
I already tried restarting my computer, uninstalling the SpeckleManager, uninstalling the connectors, disconnecting from the account, but nothing seemed to work.
Is it because I use the free trial version of Rhino and is there anything I can do to fix this ?
This is the first time we get this type of issue being reported, and both our connectors use the same code so it’s a bit weird, let’s try to debug it a bit:
is it the first time you use the Rhino connector or have you used it successfully before?
are you using a corporate laptop that might have specific firewall rules for Rhino?
As for the script, I copied it to the C# node and it seems to output “Success”, but as I am not used to using script, I am not sure I did it correctly.
I do not have an IT departement, I am currently studying architecture and using Speckle on a personal laptop. Also, if the domain is really blocked then the fact I am able to access it with the Revit connector is very weird. Is there a difference between the way Rhino uses Streams and the way Revit does ?
There is no difference between how our two connectors call our API, I thought there could have been some Firewall rules affecting Rhino. But since it’s your personal computer it’s probably not the case!
The only last thing I can think of is that it might be related to Rhino being an evaluation version…
