Problem with models and Power BI Get Data
Hi everyone, I’m Aline, and just started using Speckle and I need some assistance.
My main goal in the end it’s to build a dashboard on power bi that shows cost, planning with dates and all of that related to the 3D model but I’m quite far from it still. For now, the issue is with Naviworks and speckle:
  • Issue: I open Navisworks and I can work fine on it, but when I try to open speckle connector it just clashes.
I’m using Navisworks 2025 and the Navsiworks speckle connector upatade it’s 2.19.3
dmpuserinfo.xml (16.9 KB)
NavisWorksErrorReport.dmp (4.8 MB)
Hi @Aline_Nunes ,
Could you send us you Navisworks Logs in %appdata%/Speckle/Logs ?
Do you have other addins installed in Navisworks?
Hey @teocomi , there’s no other addins on Navisworks. I use Speckle on Revit 2025 and it doesn’t happens there.
The files you asked for:
SpeckleCoreLog20240728.txt (1.4 KB)
SpeckleCoreLog20240729.txt (4.2 KB)
Thanks in advance for the help!
Thank you, we have found the bug and will make a new release asap!
Quick update: you can install our latest pre-release, which already contains a fix:
A new stable 2.20 release is due to arrive this week!
I’ve tried this version you mentioned but I got the same error. I will wait for the new version to come and try again. Thank you for the atenttion!
My apologies, Aline, the fix was not actually included.
But it will be in a Release Candidate coming out today and in the Stable release scheduled for next week.
