Problem updated local server yml file
Hi.
I saw a lot of updates on https://app.speckle.systems/:
  • new viewer
  • filters
  • view saving
It looks really cool. :clap:
I decided to try these changes on a local server, but I didn’t see anything new :frowning:
Could you please tell me if there are plans to update the local server?
I tried to create a server following the instructions docs.speckle.systems/developers/server/getting-started in the updated documentation, but I ran into problems with the .yml file:
minio didn’t open on the site 127.0.0.1:9001 until I added the line to yml:
minio:
    image: 'minio/minio'
    command: server /data --console-address ":9001"
    restart: always
    ports:
      - '127.0.0.1:9000:9000'
      - '127.0.0.1:9001:9001' # add string
    volumes:
      - ./minio-data:/data
file-import do not start until I installed a new version
preview-service do not start until I add port:
  preview-service:
    image: speckle/speckle-preview-service:2
    restart: always
    depends_on:
      - speckle-server
    environment:
      PORT: '3003' # add string
      REDIS_URL: 'redis://redis'`
And I add environment by speckle-ingress
  speckle-ingress:
    image: speckle/speckle-docker-compose-ingress:2
    restart: always
    ports:
      - '127.0.0.1:80:8080'
    environment:
      FILE_SIZE_LIMIT_MB: "1000"
      NGINX_ENVSUBST_OUTPUT_DIR: "/etc/nginx"`
I created a busket and after that the local server started.
I may have misunderstood the instructions, but it might be worth checking.
