Hi there Alan!
I´m having problems sending to a pointed branch in my stream…
I get this message! “1. T0: One or more errors occurred.
Response status code does not indicate success: 401 (Unauthorized).”
Hi there Alan!
Hey @tomasmena ,
What version of Grasshopper connector are you using? Can you please try with latest 2.9.0-beta6 and see if you are still getting it.
Now I´m getting this
Ok, this was my bad. Can you uninstall the grasshopper connector and reinstall the recommended one? The reason why you were getting the error was that branch names with spaces need to be properly escaped. In your case, your branch URL will be:
https://speckle.xyz/streams/521b67e98f/branches/tuviale%20juntti
