Power BI viewer not interacting with other visuals
I am facing an issue with the power BI viewer as only part of the model interacts with other filters
I usually export my IFC files with only GUIDs property to keep them as light as possible and then connect the IFC files with the extra 4D and 5D data on the power BI side using the GUID as relationship ID.
I have 3 IFC files that I append on the speckle side and upload to Power BI.
I then connect the IFC model query with other tables (coming from excel files). and on my dashboard I have different filters so I can navigate the model by building/ section/material etc.
This has worked before and works now if the Query has only one IFC file.
What I noticed now is that the filters interact with only one of the IFC files while the other remain in the viewer unchanged.
I have updated the viewer today to the V3.3.4 and I am not sure if this is related to the update.
I’d appreciate any help
Hey @MoLaach,
Thanks for reporting this, I will try to see if I can reproduce. In the meantime I have some two questions:
  1. How to you federate the models in PowerBI?
  2. In the 3D Viewer do you see all the models federated correctly?
Thanks for the prompt reply
-I federate the models on the speckle side and use the link to load them to power bi as a single query.
-The viewer shows the whole model, but only part of it is interactive
Update: I made no changes and it seems to be working today.
