Hi guys,
I can’t receive a specific branch in Power BI when Branch name includes a special character.
Branch Name👇
When I deleted the special character it worked just fine. @AlanRynne, maybe you could take a look at it.
Hi guys,
Branch Name👇
oh… interesting!
There are some limitations on the way we decode branch names
. As powerBI doesn’t provide a clean native way to go from url safe
encoding to utf-8
consistently.
We’re currently using a bit of a hack I found online (which is to pass the branch name as a query parameter of a fake url… ). Seemed to work fine with most cases i tested (including emojis!) but I may have failed to check characters like
I’ll do some tests later in the day and see if I can come up with a solution, but meanwhile you could try to pass the branch name as families%26types
I may just need to force encode the branch name before decoding it back to ensure there isn’t a mixed bag of characters.
I actually changed the branch name later on. But yes, it works with %26
Ok found a nice solution for this problem! It will be included in the next release!
