I am using a Microsoft Gantt Chart plugin to tie to the 3D model visualizer in Power BI. When I select a rectangle in the Gantt chart associated with the first 4 items in the legend, the 3D viewer works as intended
However, when I select the last two items in the legend (4-Lumbing Topout and 6-Floor Frqaming) the model does not show and I get the “Couldn’t load the data for this visual See details”
I couldn’t find what this means after searching online, any idea what might be going on here? I would load more pictures to explain what’s going on, but I am unable to as a newer user.
Maybe you can share with us your powerbi dashboard and we can take a look. If the project is confidential or you don’t want to share the project here, please let me know and I will share with you a secure google drive folder.
thanks for your swift reply and changing those permissions.
I saw that discussion thread about the visual limit. To my understanding, the error I received appears to be due to the data transformations I used, not necessarily the amount of data.
Would I be able to share a folder with you instead via your email through One Drive?
