Power bi connector issue
Hi everybody.
I have a problem with the Power bi connector, I am getting this message.
Any idea how to fix this issue?
Thanks,
Hi there!
Only thing I can think of is that you’re trying to fetch a private stream using either:
  • The “Public Stream” option.
  • The “private stream” or “speckle.xyz” option, but using the wrong account.
I suggest you remove your data source credentials. this will prompt PowerBI to ask you again for the credential method you wish.
If the stream you’re trying to use is public let me know bc then it may be a bug in our logic.
You can find the data source settings here
Here’s what a speckle data source credential would look like
And here’s the multi choice panel that is only shown the first time you fetch.
Thank you very much for your help. I was logging in with a private stream, but I changed it to a public stream and it worked.
Thanks :grinning: :+1:
