Power bi - 3d visualization
I’ve exported my model to the “speckleverse” and installed the 3D visualizer on Power BI following the videos on Speckle’s tutorial page, I’ve tried intalling different versions as well as the newest ones, not the pre-releases. When I import the data it’s imported correctly, I can access the categories and everything using the data table, but the model doesn’t load on the 3D viwer, at all eventhough I can see it online.
Hi Gabriel,
Could you try with other models and tell us if they work?
I uninstalled everything and when I sent the project to the cloud, I disabled the private option and it worked. I wonder if it was the private option.
Yes, currently only Link Shareable projects are viewable inside Power BI 3D Visual. Private projects are not support atm.
