Do you know why my polyline shows incompleted?
What do you mean by “incompleted”? Should the yellow one be closed?
@pauldotnet thank for the availability,
yes it should show as closed, since it is in dynamo. I was wondering why it displays in that way, because it is not an open poly-line. not sure how call it?!
I remember there was a bug in the viewer that i fixed recently. if you’re on hestia, try hard refreshing (ctrl+shift+r), or if on your own server, do a git pull on the plugin folder.
alternatively, speckle admin is finally CI-ed on https://app.speckle.systems (use your own server endpoint to login).
