Parameter Value in speckle model is not the same unit and value in Revit model
  • Objective:
display the quantity survey for project in power bi dashboard.*
  • Issue:
the dimension of some parameter such as volume , area , thickness is not the same of revit model for example all parameter in revit model is metric but when export it the volume and area is by feet and thickness maybe be in feet or metric and in some element it is totally wrong
  • Example:
there is a pic shown the problem
- Speckle link
https://app.speckle.systems/projects/3b81369b63/models/41934e4966
Hey @ahmed.hashad ,
This seems to happen only in Revit 2020. There seems to be an API limitation, i will double check with the developers and get back to you. In the meantime, you can try sending from a later version.
