Hi all,
We have discovered a issue with the parameter value in Rhino. For example the Element Type value for the floor here is listed correct as “STB_22.0” in the viewer:
but in Rhino the value is displayed as “2127033”:
The same issue appears also with the “phaseCreated” values.
Could it be that these are the parameter IDs that are displayed instead of the parameter values in Rhino?
Greetings ![]()
