That will be awesome if we can connect nodepen onine with data speckle to explore data
, any people in here working with that ?
Well, Nodepen is already powered by Speckle. What do you mean by connecting Nodepen with Speckle data? A receive node for nodepen? Sending nodepen data to Speckle?
I mean it will be become a dynamo online allow all people can be create node to easy connect with speckle
gonna rope in the man himself @chuck ![]()
Hey! Yeah, can you say more about this Dynamo idea?
With the way I’m approaching things now, the nodes library takes a “library” of components and a set of callbacks for different actions/events (like a change in an input). More generic than earlier versions.
I’m using it, in order to do Grasshopper from the web, by passing in a “library” that looks like grasshopper components and setting callbacks that send data to my Rhino Compute / Speckle server. (A bit of hand waving there)
The model viewer also takes a Speckle stream id directly, and it checks it for new data.
I’m still getting a feel for the most comfortable way to wire things up. (What happens when user accounts are involved? What if I wanted to draw/set geometric inputs from the 3D viewer?)
What are you thinking about doing with Dynamo? I always thought it’d be difficult, because I’m not sure that our options are great for a “Revit server”. But I’ve had my plate full with Grasshopper and haven’t given it a good look.
