Hi all.
I updated the Grasshopper plugin yesterday, and now I have tihs error:
How to enable conversions?
It seems to have one?
Version I’m running currently is: 2.2.7-beta
Hi all.
Hmm… it’s been a while since I’ve bumped into this one!
Usually this means that the installation went wrong in some way, although judging by the Objects
kit being present, I’d say you may be missing the ConverterRhino6.dll
in the %appdata%/Speckle/Kits/Objects/
folder.
Could you check if that is the case?
Could you also try uninstalling the grasshopper (and rhino!) connectors and reinstalling them again?
Thanks for reporting this
Thanks for quick response Alan!
The Converter is in the folder:
I’ll check uninstalling and reinstalling.
Reinstalling didn’t work… same error.
Weird, I tried a full reinstall on my clean machine and didn’t have any problems.
What other connectors do you have installed? Also, could you send me your SUUID?
No other connectors installed I think. What is my SUUID?
That happened to me once. What I did to fix was:
And here’s how to get your SUUID: Speckle Manager | Speckle Docs
Thanks vwb!
However, when I did this, all the kits are gone.
Here my SUUID: 0b901b88-69b3-4b01-a84d-d99cdab936a3
So… just to be 100% clear. You removed the dll
s, re-installed the connector and now you get this? What are the contents of your %appdata%/speckle/kits/objects
folder after doing so?
Yes. I removed the dlls. Re-installed it and now i get this.
These are the contents now:
Maybe you could also try downgrading to the latest stable: Speckle Manager | Speckle Docs
Interesting…could those dll
's be blocked by any chance?
I’m kinda running out of ideas already… let’s arrange a quick call to look into it if you have time sometime today or monday
Hi Alan!
Thanks! I was a bit busy the last few days. Dll’s are not blocked. I can still try downgrading. Let me test that, otherwise we can plan a call.
This helped! Thanks!
Hi there!
I’m running into a similar issue I think. I just downgraded the Grasshopper connector to the latest stable version, but no luck.
I am on a Rhino 7 running at an intel-mac
MacBook M1 pro same thing happen.
So I couldn’t receive from speckle. (QGIS upload is work in MacBook M1)
Hi there @j.beneitez and @bluetux!
Thanks for bringing this up, I can reproduce this issue and we’ll be looking into this ASAP.
Can you confirm if the Rhino connector works?
A fix is on the way… but I don’t think we’ll be releasing any backwards fixes. We’re in the final stretch to release 2.16 (and currently 2.16.0-rc is available for community testing) so we’ll be releasing a new release-candidate 2.16.0-rc2
today/tomorrow that should include this fix!
Thanks again for reporting it!
Here’s the fix if you’re curious fix(all): Changes configuration of All.sln so GH converters are built on release when Release Mac by AlanRynne · Pull Request #2959 · specklesystems/speckle-sharp · GitHub
