Hi there, I´m new here. Testing the Revit Connector for the first time. Doensn´t work for me, yet. I get this message and nothing else happens: “Invalid geometry fidelity value:”
Hey @Henrik, welcome to the community! Feel free to introduce yourself to the rest of the community here
Hmmm, not ideal - thanks for posting this! To narrow this down, could you please let me know the following:
What RVT Version are you sending from?
Anything different when sending? What view do you have open when sending? Is it a 3D view or a plan view?
When did you install the next-gen connector? Possibly beneficial to try with the latest installer (3.1.2 if my memory serves me correct)
I was able to send a simple wall from various views in both RVT 24 and 25, so “unfortunately” not able to recreate the issue.
It could also be beneficial for us if you could share the log txt file with us. This can be found here: %APPDATA%/Roaming/Speckle/Logs/Revit 2025. They are date stamped which could help you find the correct one. I would typically also ask to share the problematic model with us, but if it’s only a simple wall that shouldn’t bring about any revelations.
