Hello Specklers,
We are trying to jump into the v2 wagon from an existing deployment (azure)
I am using the newest docker-compose.yml found in your docs the only major change in the docker file is that we are still using postgress13. Unfortunately we get an error at deployment here are the logs:
Any ideas?
Thanks in advance!
Attaching to speckv2_speckle-server_1, speckv2_minio_1, speckv2_speckle-ingress_1, speckv2_postgres_1, speckv2_redis_1, traefik, speckv2_speckle-frontend-2_1
minio_1 | MinIO Object Storage Server
minio_1 | Copyright: 2015-2024 MinIO, Inc.
minio_1 | License: GNU AGPLv3 - https://www.gnu.org/licenses/agpl-3.0.html
minio_1 | Version: RELEASE.2024-05-10T01-41-38Z (go1.22.3 linux/amd64)
minio_1 |
minio_1 | API: http://172.18.0.6:9000 http://127.0.0.1:9000
minio_1 | WebUI: http://172.18.0.6:9001 http://127.0.0.1:9001
minio_1 |
minio_1 | Docs: https://min.io/docs/minio/linux/index.html
minio_1 | Status: 1 Online, 0 Offline.
minio_1 | STARTUP WARNINGS:
minio_1 | - Detected default credentials 'minioadmin:minioadmin', we recommend that you change these values with 'MINIO_ROOT_USER' and 'MINIO_ROOT_PASSWORD' environment variab
les
minio_1 | - The standard parity is set to 0. This can lead to data loss.
postgres_1 |
postgres_1 | PostgreSQL Database directory appears to contain a database; Skipping initialization
postgres_1 |
postgres_1 | 2024-05-23 16:47:29.589 UTC [1] LOG: starting PostgreSQL 13.1 on x86_64-pc-linux-musl, compiled by gcc (Alpine 10.2.1_pre1) 10.2.1 20201203, 64-bit
postgres_1 | 2024-05-23 16:47:29.589 UTC [1] LOG: listening on IPv4 address "0.0.0.0", port 5432
postgres_1 | 2024-05-23 16:47:29.589 UTC [1] LOG: listening on IPv6 address "::", port 5432
postgres_1 | 2024-05-23 16:47:29.605 UTC [1] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
postgres_1 | 2024-05-23 16:47:29.619 UTC [20] LOG: database system was shut down at 2024-05-23 16:47:15 UTC
postgres_1 | 2024-05-23 16:47:29.628 UTC [1] LOG: database system is ready to accept connections
speckle-frontend-2_1 | /nodejs/bin/node[6]: ../src/node_platform.cc:68:std::unique_ptr<long unsigned int> node::WorkerThreadsTaskRunner::DelayedTaskScheduler::Start(): Assertion `(0) == (u
v_thread_create(t.get(), start_thread, this))' failed.
speckle-frontend-2_1 | 1: 0xb9a300 node::Abort() [/nodejs/bin/node]
speckle-frontend-2_1 | 2: 0xb9a37e [/nodejs/bin/node]
speckle-frontend-2_1 | 3: 0xc0848e [/nodejs/bin/node]
speckle-frontend-2_1 | 4: 0xc08571 node::NodePlatform::NodePlatform(int, v8::TracingController*, v8::PageAllocator*) [/nodejs/bin/node]
speckle-frontend-2_1 | 5: 0xb56223 node::InitializeOncePerProcess(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11:
:basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, node::ProcessFlags::Flags) [/nodejs/bin/node]
speckle-frontend-2_1 | 6: 0xb5687b node::Start(int, char**) [/nodejs/bin/node]
speckle-frontend-2_1 | 7: 0x7f709388b24a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | 8: 0x7f709388b305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | 9: 0xad58ae _start [/nodejs/bin/node]
speckle-frontend-2_1 | 7: 0x7f721e55424a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | 8: 0x7f721e554305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | 7: 0x7f90ebbcf24a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | 8: 0x7f90ebbcf305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | /nodejs/bin/node[7]: ../src/node_platform.cc:68:std::unique_ptr<long unsigned int> node::WorkerThreadsTaskRunner::DelayedTaskScheduler::Start(): Assertion `(0) == (u
speckle-frontend-2_1 | 7: 0x7f6c7584c24a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | 8: 0x7f6c7584c305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | 7: 0x7fc83df9324a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | 8: 0x7fc83df93305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | 7: 0x7f8d63c3424a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | 8: 0x7f8d63c34305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | 7: 0x7fd09349024a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | 8: 0x7fd093490305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | 7: 0x7fde911df24a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-frontend-2_1 | 8: 0x7fde911df305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
redis_1 | 1:C 23 May 2024 16:47:30.428 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being dis
abled, it can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf an
d then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
redis_1 | 1:C 23 May 2024 16:47:30.428 * oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
redis_1 | 1:C 23 May 2024 16:47:30.428 * Redis version=7.2.5, bits=64, commit=00000000, modified=0, pid=1, just started
redis_1 | 1:C 23 May 2024 16:47:30.428 # Warning: no config file specified, using the default config. In order to specify a config file use redis-server /path/to/redis.conf
redis_1 | 1:M 23 May 2024 16:47:30.428 * monotonic clock: POSIX clock_gettime
redis_1 | 1:M 23 May 2024 16:47:30.435 * Running mode=standalone, port=6379.
redis_1 | 1:M 23 May 2024 16:47:30.435 * Server initialized
redis_1 | 1:M 23 May 2024 16:47:30.436 * Loading RDB produced by version 7.2.5
redis_1 | 1:M 23 May 2024 16:47:30.436 * RDB age 15 seconds
redis_1 | 1:M 23 May 2024 16:47:30.436 * RDB memory usage when created 0.85 Mb
redis_1 | 1:M 23 May 2024 16:47:30.436 * Done loading RDB, keys loaded: 1, keys expired: 0.
redis_1 | 1:M 23 May 2024 16:47:30.436 * DB loaded from disk: 0.000 seconds
redis_1 | 1:M 23 May 2024 16:47:30.436 * Ready to accept connections tcp
speckle-ingress_1 | /docker-entrypoint.sh: /docker-entrypoint.d/ is not empty, will attempt to perform configuration
speckle-ingress_1 | /docker-entrypoint.sh: Looking for shell scripts in /docker-entrypoint.d/
speckle-ingress_1 | /docker-entrypoint.sh: Ignoring /docker-entrypoint.d/10-listen-on-ipv6-by-default.sh, not executable
speckle-ingress_1 | /docker-entrypoint.sh: Ignoring /docker-entrypoint.d/15-local-resolvers.envsh, not executable
speckle-ingress_1 | /docker-entrypoint.sh: Ignoring /docker-entrypoint.d/20-envsubst-on-templates.sh, not executable
speckle-ingress_1 | /docker-entrypoint.sh: Ignoring /docker-entrypoint.d/30-tune-worker-processes.sh, not executable
speckle-ingress_1 | /docker-entrypoint.sh: Configuration complete; ready for start up
speckle-ingress_1 | 2024/05/23 16:47:30 [notice] 1#1: using the "epoll" event method
speckle-ingress_1 | 2024/05/23 16:47:30 [notice] 1#1: nginx/1.25.4
speckle-ingress_1 | 2024/05/23 16:47:30 [notice] 1#1: built by gcc 12.2.0 (Debian 12.2.0-14)
speckle-ingress_1 | 2024/05/23 16:47:30 [notice] 1#1: OS: Linux 5.15.0-1064-azure
speckle-ingress_1 | 2024/05/23 16:47:30 [notice] 1#1: getrlimit(RLIMIT_NOFILE): 1048576:1048576
speckle-ingress_1 | 2024/05/23 16:47:30 [notice] 1#1: start worker processes
speckle-ingress_1 | 2024/05/23 16:47:30 [notice] 1#1: start worker process 12
speckle-ingress_1 | 2024/05/23 16:47:30 [notice] 1#1: start worker process 13
traefik | time="2024-05-23T16:47:30Z" level=info msg="Configuration loaded from flags."
traefik | time="2024-05-23T16:47:31Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
he server is ignored" container=speckle-frontend-2-speckv2-32e1a4d7060b8984bfb17ceac2546990d5cce287586b6646271f83cbd649f8b1 providerName=docker
traefik | time="2024-05-23T16:47:32Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
he server is ignored" providerName=docker container=speckle-frontend-2-speckv2-32e1a4d7060b8984bfb17ceac2546990d5cce287586b6646271f83cbd649f8b1
traefik | time="2024-05-23T16:47:34Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
traefik | time="2024-05-23T16:47:35Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
traefik | time="2024-05-23T16:47:37Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
traefik | time="2024-05-23T16:47:38Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
traefik | time="2024-05-23T16:47:40Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
traefik | time="2024-05-23T16:47:41Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
traefik | time="2024-05-23T16:47:42Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
traefik | time="2024-05-23T16:47:43Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
traefik | time="2024-05-23T16:47:44Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
traefik | time="2024-05-23T16:47:45Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
traefik | time="2024-05-23T16:47:46Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
traefik | time="2024-05-23T16:47:49Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
traefik | time="2024-05-23T16:47:50Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
traefik | time="2024-05-23T16:47:52Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
traefik | time="2024-05-23T16:47:57Z" level=error msg="service \"speckle-frontend\" error: unable to find the IP address for the container \"/speckv2_speckle-frontend-2_1\": t
speckle-server_1 | node[1]: ../src/node_platform.cc:68:std::unique_ptr<long unsigned int> node::WorkerThreadsTaskRunner::DelayedTaskScheduler::Start(): Assertion `(0) == (uv_thread_cre
speckle-server_1 | 1: 0xb9a300 node::Abort() [node]
speckle-server_1 | 2: 0xb9a37e [node]
speckle-server_1 | 3: 0xc0848e [node]
speckle-server_1 | 4: 0xc08571 node::NodePlatform::NodePlatform(int, v8::TracingController*, v8::PageAllocator*) [node]
speckle-server_1 | 5: 0xb56223 node::InitializeOncePerProcess(std::vector<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11:
:basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, node::ProcessFlags::Flags) [node]
speckle-server_1 | 6: 0xb5687b node::Start(int, char**) [node]
speckle-server_1 | 7: 0x7f73b177824a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 8: 0x7f73b1778305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 9: 0xad58ae _start [node]
speckle-server_1 | 7: 0x7f22fe2be24a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 8: 0x7f22fe2be305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 7: 0x7f1d42dd524a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 8: 0x7f1d42dd5305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 7: 0x7f24d4d7724a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 8: 0x7f24d4d77305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 7: 0x7fdaffe5e24a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 8: 0x7fdaffe5e305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 7: 0x7fed65f1424a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 8: 0x7fed65f14305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 7: 0x7f9051ca424a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 8: 0x7f9051ca4305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 7: 0x7ff2cdb7924a [/lib/x86_64-linux-gnu/libc.so.6]
speckle-server_1 | 8: 0x7ff2cdb79305 __libc_start_main [/lib/x86_64-linux-gnu/libc.so.6]
