It would be really useful if the zoom can use the double-clicked object as target, not only the rotate. Thanks!
Like this?
No, the issue I’m having is that if I double click to select an object and make it the centre of rotation, when I zoom in with my mouse scroll, it doesn’t zoom in with the object as target.
For example, I want to measure the wall thickness of that SHS, but I can’t.
This shouldn’t be the case. Can you share the Speckle Model URL?
