Multiple RenderMaterial instances per object in renderMaterialProxies
Hi folks,
I’ve observed a Revit model having objects defined in the renderMaterialProxies structure that point to multiple RenderMaterial definitions. That is:
renderMaterialProxy
  • [0]
    • value → RenderMaterial “CLAD_Terracotta Tile_300w*F2F_batten_COLOUR 1”
    • objects → “7e43e0bd-afce-42e3-a12f-973a23ef9f2b”
  • [1]
    • value → RenderMaterial “CLAD_Terracotta Tile_300w*F2F_batten_COLOUR 2”
  • [2]
    • value → RenderMaterial “CLAD_Terracotta Tile_300w*F2F_batten_COLOUR 3”
  • [3]
    • value → RenderMaterial “CLAD_Terracotta Tile_300w*F2F_batten_COLOUR 4”
Do you know why this occurs and whether it is by design? If it is, then what is the correct way to assign material to the mesh object defined in ‘7e43e0bd-afce-42e3-a12f-973a23ef9f2b’ here?
Tim.
Hi @tlewis,
At first glance, it does not look right. For better understanding, is this generated with the latest connector? Is it possible to share the model URL so we can have a look?
