Hey there,
I’ve been using Speckle for quite some time now and I created two accounts (both personal but with two email addresses associated).
Now I would like to close one but without loosing the streams data.
I added my other account as a contributor for all the streams but I’m not sure if it’s enough to prevent the streams being removed if I delete the other account.
Hey Matteo, thank you for the prompt reply!
I have a quite different interface (accessing via web - speckle.xyz).
I managed to get the job done.
I attach a couple picture for other users benefit that might encounter the same needs.
Picture 1
In the owner account I went to Stream Home > Collaborators, then selected the dropdown in the Contributors pane and changed the role to stream:owner
Picture 2
After doing that, the other account avatar moved to the Owners pane.
Additionally, as the original owner is no longer the only one, it can leave the Stream and/or change its role to Contributor or to Reviewer
