Model Groups with Speckle Rhino Grasshopper components
Hi all,
Is it possible to create / modify Revit “Model Groups” with the Speckle Revit Grasshopper components?
Thank you for your help.
Best, Sean
Hey @SeanLineham,
No, it’s not possible. But I’m really curious about what you’re trying to achieve! If you could share more context, that would help us consider it for our backlog.
Hey Mucahit, I am working on a modular project and was trying to use Model Groups to control each module, and use Rhino to create these modules.
With the same context, we have many steel connection details - can you create In-Place components with the Speckle Grasshopper components? My workaround is currently to us DirectShapes but you cannot dimension from them. Therefore, I export the brep’s wireframe as ModelCurves to provide something to snap to. I have also tried the FreeformElement component but that seems to break the Speckle link as a dialog box referring to Revit 2014 opens up on each receive.
Thanks so much for your help.
Best, Sean
