Login is blocked
same problem. As i log in from browser there is no problem but as iam trying to login by opening the specklemanager from grasshopper rhino and directed to “https://app.speckle.systems” for login i get the same error.
Hi @osman_zihni ,
Please note that Automate is currently only available in our testing server, for which you need to use:
Let me know if this works!
hi @teocomi
ı have copied the link to manager for speckle as a custom server URl and tried that way to log in but it happened the same problem. Firstly authorized and couldnt connect to website afterwards.
Could you try resetting your password and trying again?
Also, if this is not Automate related, I’ll move it to a separate topic…
hi @tecomi
It has worked without resetting my password.
Thank you wery much.
