Hi everyone!
I’m trying to instantiate the same geometry more than once (I’m using a local OBJ file atm). Currently, each node belonging to the meshes are actually shown and can be manipulated, however, their individual parent node share the exact same id (matching the file path), which ofc gives some issues later down the line. I have tried to change the id in several ways. Is there a way to do this?
Or even better, is there a way to instantiate/ copy a geometry more than once without the additional overhead of loading from file?
The last thing I tried was to follow this example from the docs:
const objData:string | ArrayBuffer = '<your OBJ resource data>'
/** Create a loader for the .obj data */
const loader = new ObjLoader(viewer.getWorldTree(), '<user defined id>', objData);
/** Load the obj data */
await viewer.loadObject(loader, true);
It seems adding the ‘user defined Id’ will cause an error in the loader, since no geometries are being shown.
