Hello everyone,
I have a construction kit-of-parts (building compontents such as walls, slabs, beams, columns etc.) with properties on Speckle which I would like to load into Archicad to use in the corresponding native Archicad functions (composites, beams, columns etc.).
By using the connector I just seem to get the model as represented in Speckle with the individual layers but Archicad doesnt seem to have a way to convert this into a composite without going into the usual composite “creator” where you manually add all the layers/skins.
Does anyone happen to have experience with this? Is there a way to load the parts on Speckle via the Archicad attribute manager?
Thanks!!
