Loading Components to CSI (SAP & ETABs)
  • Objective:
I’m trying to run through the example video on GH to CSI but with my own example model. I got nearly to the end but loading is not working for me for some reason.
  • Issue:
I seem to have done all the instructions correctly but nothing shows up in SAP2000 or ETABs, no load case, no load pattern, no load assignments from the inputs I have.
  • Example:
  • Speckle link:
https://speckle.xyz/streams/c6681ebf27
Hey @Tushar_Nagananda,
Looking at the commit that you shared, it’s no surprise that you didn’t see any loads populate in ETABS.
As you can see everything in your “Model” object has a value except for loads. I’m not really a GH user so I’m not sure how to go about fixing this on the GH side. Do you have any idea why this value is sending as null?
