Linked models with parcial sending
I am sending from Revit to Speckle a federed model with several linked models. Each building in Figure 1 is a linked model.
However, just one building is correctly sended. We can see the difference between revit model and speckle model in Figure 2.
Someone can help me?
Figure 1
Figure 2
Hi @JORDANA,
Could you share a snapshot of the Report after the Send to Speckle? After sending, you’ll find that in the top right of the connector (ignore the fact that my screenshot is from the ETABS connector, that’s just what I had open on my screen :smile: )
And just to hone down on the issue further, could you try just sending one of the buildings which didn’t work well separately (e.g. Building 1 or 2) and see if that pulls through?
Here is the report about the failed objects:
Wall ALAMBRADO 3348f664-66af-459b-8696-d4559d563599-003e4757 Failed
Referência de objeto não definida para uma instância de um objeto.
Floor BLOCO INTERTRAVADO 2_5cm 3348f664-66af-459b-8696-d4559d563599-003e6941 Failed
Floor LAJE CONCRETO 10cm 3348f664-66af-459b-8696-d4559d563599-003e696c Failed
Wall ALAMBRADO edb5f961-f1c2-446e-a5fa-f0cc02ddcaaa-003e72bb Failed
Floor LAJE CONCRETO 10cm edb5f961-f1c2-446e-a5fa-f0cc02ddcaaa-003e746e Failed
Floor LAJE CONCRETO 10cm 67ca1470-8c1d-4be4-a669-61d8bcbfc096-003e9a03 Failed
Floor LAJE CONCRETO 10cm b4674b27-175d-4820-93dd-d3e6aa8daca1-003ed832 Failed
Floor LAJE CONCRETO 10cm fed4c250-b119-454b-a537-a2d6e763a618-003ee8e3 Failed
Floor LAJE CONCRETO 10cm 71b1b0a0-7996-4836-a5dd-50c6b81fdfcd-003eec7b Failed
Floor LAJE CONCRETO 10cm 71b1b0a0-7996-4836-a5dd-50c6b81fdfcd-003ef36b Failed
Floor LAJE CONCRETO 10cm 71b1b0a0-7996-4836-a5dd-50c6b81fdfcd-003efcef Failed
Floor LAJE CONCRETO 10cm 71b1b0a0-7996-4836-a5dd-50c6b81fdfcd-003f00a2 Failed
Floor LAJE CONCRETO 10cm 71b1b0a0-7996-4836-a5dd-50c6b81fdfcd-003f0ba1 Failed
Floor LAJE CONCRETO 10cm 71b1b0a0-7996-4836-a5dd-50c6b81fdfcd-003f0e6c Failed
Floor LAJE CONCRETO 10cm 71b1b0a0-7996-4836-a5dd-50c6b81fdfcd-003f188a Failed
Floor LAJE CONCRETO 10cm 71b1b0a0-7996-4836-a5dd-50c6b81fdfcd-003f1a6c Failed
Floor LAJE CONCRETO 10cm 71b1b0a0-7996-4836-a5dd-50c6b81fdfcd-003f1cbe Failed
Floor LAJE CONCRETO 10cm 71b1b0a0-7996-4836-a5dd-50c6b81fdfcd-003f1d69 Failed
Floor LAJE CONCRETO 10cm 71b1b0a0-7996-4836-a5dd-50c6b81fdfcd-003f258e Failed
Floor LAJE CONCRETO 10cm fea3931f-0063-4870-b57a-905b1f0ff632-003f55a1 Failed
Floor LAJE CONCRETO 10cm fea3931f-0063-4870-b57a-905b1f0ff632-003f616c Failed
Floor LAJE CONCRETO 10cm cb347dcd-1366-495c-a885-fb1a65752e0f-003f8684 Failed
Floor LAJE CONCRETO 10cm cb347dcd-1366-495c-a885-fb1a65752e0f-003f8816 Failed
Floor LAJE CONCRETO 10cm cb347dcd-1366-495c-a885-fb1a65752e0f-003f8835 Failed
Floor LAJE CONCRETO 10cm cb347dcd-1366-495c-a885-fb1a65752e0f-003f8980 Failed
Floor LAJE CONCRETO 10cm cb347dcd-1366-495c-a885-fb1a65752e0f-003f8adb Failed
Floor LAJE CONCRETO 10cm cb347dcd-1366-495c-a885-fb1a65752e0f-003f8c02 Failed
Floor LAJE CONCRETO 10cm cb347dcd-1366-495c-a885-fb1a65752e0f-003f92cc Failed
Floor LAJE CONCRETO 10cm cb347dcd-1366-495c-a885-fb1a65752e0f-003fa01b Failed
Floor LAJE CONCRETO 10cm cb347dcd-1366-495c-a885-fb1a65752e0f-003fa593 Failed
Floor BRITA c1a463a0-8354-4216-89bb-a3a9b7887db5-003fbb9c Failed
Floor BRITA c1a463a0-8354-4216-89bb-a3a9b7887db5-003fbf69 Failed
Floor GRAMA_5cm c1a463a0-8354-4216-89bb-a3a9b7887db5-003fc525 Failed
Floor BLOCO INTERTRAVADO_5cm c1a463a0-8354-4216-89bb-a3a9b7887db5-003fc56f Failed
Floor BLOCO INTERTRAVADO_5cm c1a463a0-8354-4216-89bb-a3a9b7887db5-003fc92c Failed
Floor LAJE CONCRETO 10cm 4dd87ea1-3929-4c19-ac25-7f79b39b4364-00415fe2 Failed
Floor LAJE CONCRETO 10cm 4dd87ea1-3929-4c19-ac25-7f79b39b4364-0041600b Failed
Floor LAJE CONCRETO 10cm 4dd87ea1-3929-4c19-ac25-7f79b39b4364-00416095 Failed
Floor LAJE CONCRETO 10cm 691af755-590d-44e0-ae11-2cb771fc2092-00416bf3 Failed
Floor BASALTO REGULAR_5cm 691af755-590d-44e0-ae11-2cb771fc2092-00416c2a Failed
Floor LAJE CONCRETO 10cm 08d26380-f114-4af3-b688-86a9a98f918a-003e47bb Failed
Floor LAJE CONCRETO 20cm 08d26380-f114-4af3-b688-86a9a98f918a-003e57b5 Failed
Floor LAJE CONCRETO 17cm 08d26380-f114-4af3-b688-86a9a98f918a-003e5e10 Failed
Wall ALAMBRADO_SEM PILAR 08d26380-f114-4af3-b688-86a9a98f918a-003e7b51 Failed
Wall ALAMBRADO_SEM PILAR 08d26380-f114-4af3-b688-86a9a98f918a-003e7b97 Failed
Wall ALAMBRADO_SEM PILAR 08d26380-f114-4af3-b688-86a9a98f918a-003e81e7 Failed
Wall ALAMBRADO_SEM PILAR 08d26380-f114-4af3-b688-86a9a98f918a-003e82fe Failed
Wall ALAMBRADO_SEM PILAR 08d26380-f114-4af3-b688-86a9a98f918a-003e8399 Failed
Wall ALAMBRADO_SEM PILAR 08d26380-f114-4af3-b688-86a9a98f918a-003e8476 Failed
Wall ALAMBRADO_SEM PILAR 08d26380-f114-4af3-b688-86a9a98f918a-003e8501 Failed
Wall GRADE 5cb9f9f3-f42e-4546-b009-479bd1048a73-003ea671 Failed
Wall GRADE 5cb9f9f3-f42e-4546-b009-479bd1048a73-003eaf7d Failed
Floor LAJE CONCRETO 10cm 5cb9f9f3-f42e-4546-b009-479bd1048a73-003ecf82 Failed
Floor LAJE CONCRETO 10cm 5cb9f9f3-f42e-4546-b009-479bd1048a73-003eefa5 Failed
Wall GRADE 7f2fccbf-a1dc-4bdb-a27e-fd776288c491-003f0931 Failed
Wall GRADE 7f2fccbf-a1dc-4bdb-a27e-fd776288c491-003f0b04 Failed
Wall GRADE 7f2fccbf-a1dc-4bdb-a27e-fd776288c491-003f0e74 Failed
Wall GRADE 7f2fccbf-a1dc-4bdb-a27e-fd776288c491-003f12d7 Failed
Floor LAJE CONCRETO 15cm 2 f043c4ae-0a9a-455b-af17-5484ec411aca-003e81aa Failed
Floor LAJE CONCRETO 10cm fa6437f9-58f6-43a0-a942-52979ce45020-003eb961 Failed
Wall GRADE b0596a9f-ff90-4ce3-a496-ee160c9a886c-003f6f54 Failed
Wall GRADE b0596a9f-ff90-4ce3-a496-ee160c9a886c-003f748e Failed
Floor LAJE CONCRETO 10cm b787ef2e-d6f4-4b78-bc92-b086171a5806-003fa5af Failed
Floor LAJE CONCRETO 10cm b787ef2e-d6f4-4b78-bc92-b086171a5806-003fb8af Failed
Floor LAJE CONCRETO 10cm 5cb820e6-5ed3-4360-aeaf-2dfb5378c53a-003fd145 Failed
Floor LAJE CONCRETO 10cm ed48d911-c817-4271-98e0-e166542ed70c-003fdaa6 Failed
Floor LAJE CONCRETO 10cm ed48d911-c817-4271-98e0-e166542ed70c-003fe944 Failed
Floor LAJE CONCRETO 28 fd55a9f9-11c4-457f-b09e-e56c2412e978-00404d29 Failed
Floor LAJE CONCRETO 10cm fd55a9f9-11c4-457f-b09e-e56c2412e978-004056e9 Failed
Floor LAJE CONCRETO 10cm fd55a9f9-11c4-457f-b09e-e56c2412e978-00405c65 Failed
Floor PISO CONCRETO_100x100cm x10 e41dd9f4-da68-414d-a5a9-a06f0e4ec645-00412db2 Failed
Wall GRADE 6e97614b-e56f-4d7a-97e4-9697f70414f9-004158e4 Failed
Wall GRADE 6e97614b-e56f-4d7a-97e4-9697f70414f9-00415ba6 Failed
Wall GRADE 6e97614b-e56f-4d7a-97e4-9697f70414f9-00415d21 Failed
Floor LAJE CONCRETO 10cm da81221b-3186-4d46-bb26-22023d1e9163-0041863c Failed
Wall GRADE da81221b-3186-4d46-bb26-22023d1e9163-0041883d Failed
Wall GRADE da81221b-3186-4d46-bb26-22023d1e9163-00418879 Failed
Wall GRADE a80d558f-c53f-4c41-9243-a5bd67cae845-00416bcb Failed
Wall GRADE a80d558f-c53f-4c41-9243-a5bd67cae845-00416c22 Failed
Floor PISO CERÂMICO_30x30cm 2 17 ESPESSURA a80d558f-c53f-4c41-9243-a5bd67cae845-00416f57 Failed
Wall GRADE 300b7baf-164e-4662-86ca-d2fd152af395-004193cc Failed
Wall GRADE 300b7baf-164e-4662-86ca-d2fd152af395-00419405 Failed
Floor LAJE CONCRETO 10cm f67ec463-6010-479a-8482-060d9c5644c3-0041d214 Failed
Sorry, the report is in Portugues!
I sent only Building 1 and its worked well
Hey @JORDANA,
If sending just one building works well, this indicates a linked model issue (especially if the five buildings are duplicates of each other). But I would have to dig a bit deeper to know for sure. Options here, would be to:
Option 1: Send the five buildings separately (i.e. create a sub-model field for each of your buildings). To have all of the buildings in the web viewer, you can use the “Add” option under Models to federate your project.
Option 2: Send me the Revit file with the linked models (if you’re able to) so I can debug on my end. You should have received a separate email from me with a link to a folder where you can upload everything.
Thanks.
Federated my model by using speckle solved the problem!
Hi @JORDANA,
There were issues with copy pasted linked models and they have been addressed with next gen Revit connector. You can try it by getting it from here.
