hi, I am having an issue viewing object meshes with same geometry purposefully put on separate layers.
one layer ‘zones’ denoting the sufaces to a zone and one layer for surfaces and a another for windows
the zones layer is showing fine and but the other layers ticked to visible are not showing:
zones layer turned off but other layers which are on are not showing:
ideally what i want is when i turn the zones layer it should look like this when i turn off the zone layer:
i have tried 2 approaches regarding layers below which both have the same result, don’t know if that makes a difference
some other information that may be of use
there are
120 objects in the zone layer
2 in openings layer
84 in surfaces
206 objects with 3 layers
https://hestia.speckle.works/api/streams/eXP7dM7y2
https://hestia.speckle.works/api/streams/eXP7dM7y2/objects
206 objects with 206 layers
https://hestia.speckle.works/api/streams/6GlP9kwuk
https://hestia.speckle.works/api/streams/6GlP9kwuk/objects
