Large file upload from other domains (CORS)
Hi! I see the ifc-fileupload is under development and things are changing rapidly. Very nice! @fabians
Sometime last or this week you guys enabled the large file import feature on the main speckle server if I am not mistaken?
Last week I only got the legacy uploader working and this week I no longer get “The large file import feature is not enabled on this server…”.
Now I wanted to switch to the new one since I am guessing there are several advantages to it? I.e. a larger maximum filesize?
I am probably jumping a bit too early on it given that it is so fresh.
During testing of the new signed upload url method I am running into CORS issues. My guess is that the bucket is configured to only allow “https://app.speckle.systems” as origin. My goal is an easy ifc file upload from our domain without having to switch to the speckle dashboard.
Now to my main question:
Is it possible to configure the CORS setting for file uploads differently?
I understand it has some security implications. If it is not possible to change this restriction it might be possible to supply a trusted origin to the “generateUploadUrl” mutation that then configures the cors? -I don’t have much s3/digitalocean experience to know if that is even remotely possible.
Let me know your thoughts, for now I can use the legacy api based method but I don’t know if you are planning to deprecate/remove it at some point.
I could also dig a bit deeper into the speckle codebase to come up with a solution proposal but I wanted to start this discussion beforehands.
Maybe I am just doing it wrong.
Thanks a lot!
Sebastian
