Trying to read Speckle stream in NET Framework 4.8, works fine for .NET 6. The line it is breaking at is SpeckleBase = Helpers.Receive(projectURL).Result;, the error I am getting is TypeInitializationException: The type initializer for 'Microsoft.Data.Sqlite.SqliteConnection' threw an exception.
Hi, @imanwarsame
Please could you try running dotnet restore command from an IDE terminal, followed by a clean re-build of your project.
This should be done after switching between .net version to refresh nuget dependencies for the target .net runtime.
Please let us know if this doesn’t resolve your issue, I’d be happy to help investigate further.
Hi @Jedd, have tried that and didn’t work. I also created a fresh project using NET framework 4.8 and still have the same error
Ok, so we’ve investigated.
In your csproj file, you must specify a PlatformTarget in order for the build to copy the correct e_sqlite.dll files.
For example
<Project Sdk="Microsoft.NET.Sdk">
<PropertyGroup>
<OutputType>Exe</OutputType>
<TargetFramework>net48</TargetFramework>
<PlatformTarget>AnyCPU</PlatformTarget>
</PropertyGroup>
<ItemGroup>
<PackageReference Include="Speckle.Core" Version="2.14.2" />
</ItemGroup>
</Project>
Hi @Jedd, thanks for your reply. Unfortunately, it’s still not working (same error) my CSPROJ is below.
<?xml version="1.0" encoding="utf-8"?>
<Project ToolsVersion="15.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
<Import Project="$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props" Condition="Exists('$(MSBuildExtensionsPath)\$(MSBuildToolsVersion)\Microsoft.Common.props')" />
<PropertyGroup>
<Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
<Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
<ProjectGuid>{3DD56EE0-EABD-4439-9EE5-52C7618922B4}</ProjectGuid>
<RootNamespace>ConsoleApp1</RootNamespace>
<AssemblyName>ConsoleApp1</AssemblyName>
<TargetFrameworkVersion>v4.8</TargetFrameworkVersion>
<FileAlignment>512</FileAlignment>
<AutoGenerateBindingRedirects>true</AutoGenerateBindingRedirects>
<Deterministic>true</Deterministic>
<NuGetPackageImportStamp>
</NuGetPackageImportStamp>
</PropertyGroup>
<PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
<DebugSymbols>true</DebugSymbols>
<DebugType>full</DebugType>
<Optimize>false</Optimize>
<OutputPath>bin\Debug\</OutputPath>
<DefineConstants>DEBUG;TRACE</DefineConstants>
<ErrorReport>prompt</ErrorReport>
<WarningLevel>4</WarningLevel>
</PropertyGroup>
<PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
<DebugType>pdbonly</DebugType>
<Optimize>true</Optimize>
<OutputPath>bin\Release\</OutputPath>
<DefineConstants>TRACE</DefineConstants>
</PropertyGroup>
<ItemGroup>
<Reference Include="GraphQL.Client, Version=5.1.1.0, Culture=neutral, processorArchitecture=MSIL">
<HintPath>..\packages\GraphQL.Client.5.1.1\lib\net461\GraphQL.Client.dll</HintPath>
</Reference>
<Reference Include="GraphQL.Client.Abstractions, Version=5.1.1.0, Culture=neutral, processorArchitecture=MSIL">
<HintPath>..\packages\GraphQL.Client.Abstractions.5.1.1\lib\netstandard2.0\GraphQL.Client.Abstractions.dll</HintPath>
</Reference>
<Reference Include="GraphQL.Client.Abstractions.Websocket, Version=5.1.1.0, Culture=neutral, processorArchitecture=MSIL">
<HintPath>..\packages\GraphQL.Client.Abstractions.Websocket.5.1.1\lib\netstandard2.0\GraphQL.Client.Abstractions.Websocket.dll</HintPath>
</Reference>
<Reference Include="GraphQL.Primitives, Version=5.1.1.0, Culture=neutral, processorArchitecture=MSIL">
<HintPath>..\packages\GraphQL.Primitives.5.1.1\lib\netstandard2.0\GraphQL.Primitives.dll</HintPath>
</Reference>
<Reference Include="Microsoft.Bcl.AsyncInterfaces, Version=5.0.0.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51, processorArchitecture=MSIL">
<HintPath>..\packages\Microsoft.Bcl.AsyncInterfaces.5.0.0\lib\net461\Microsoft.Bcl.AsyncInterfaces.dll</HintPath>
</Reference>
<Reference Include="Microsoft.Data.Sqlite, Version=7.0.3.0, Culture=neutral, PublicKeyToken=adb9793829ddae60, processorArchitecture=MSIL">
<HintPath>..\packages\Microsoft.Data.Sqlite.Core.7.0.3\lib\netstandard2.0\Microsoft.Data.Sqlite.dll</HintPath>
</Reference>
<Reference Include="Objects, Version=2.14.2.10781, Culture=neutral, processorArchitecture=MSIL">
<HintPath>..\packages\Speckle.Objects.2.14.2\lib\netstandard2.0\Objects.dll</HintPath>
</Reference>
<Reference Include="Polly, Version=7.0.0.0, Culture=neutral, PublicKeyToken=c8a3ffc3f8f825cc, processorArchitecture=MSIL">
<HintPath>..\packages\Polly.7.2.3\lib\net472\Polly.dll</HintPath>
</Reference>
<Reference Include="Polly.Contrib.WaitAndRetry, Version=1.0.0.0, Culture=neutral, PublicKeyToken=17ed651729209acc, processorArchitecture=MSIL">
<HintPath>..\packages\Polly.Contrib.WaitAndRetry.1.1.1\lib\net472\Polly.Contrib.WaitAndRetry.dll</HintPath>
</Reference>
<Reference Include="Polly.Extensions.Http, Version=3.0.0.0, Culture=neutral, PublicKeyToken=c8a3ffc3f8f825cc, processorArchitecture=MSIL">
<HintPath>..\packages\Polly.Extensions.Http.3.0.0\lib\netstandard2.0\Polly.Extensions.Http.dll</HintPath>
</Reference>
<Reference Include="Sentry, Version=3.29.0.0, Culture=neutral, PublicKeyToken=fba2ec45388e2af0, processorArchitecture=MSIL">
<HintPath>..\packages\Sentry.3.29.0\lib\net461\Sentry.dll</HintPath>
</Reference>
<Reference Include="Sentry.Serilog, Version=3.29.0.0, Culture=neutral, PublicKeyToken=fba2ec45388e2af0, processorArchitecture=MSIL">
<HintPath>..\packages\Sentry.Serilog.3.29.0\lib\net461\Sentry.Serilog.dll</HintPath>
</Reference>
<Reference Include="Serilog, Version=2.0.0.0, Culture=neutral, PublicKeyToken=24c2f752a8e58a10, processorArchitecture=MSIL">
<HintPath>..\packages\Serilog.2.12.0\lib\net47\Serilog.dll</HintPath>
</Reference>
<Reference Include="Serilog.Enrichers.ClientInfo, Version=0.0.0.0, Culture=neutral, processorArchitecture=MSIL">
<HintPath>..\packages\Serilog.Enrichers.ClientInfo.1.2.0\lib\net462\Serilog.Enrichers.ClientInfo.dll</HintPath>
</Reference>
<Reference Include="Serilog.Enrichers.GlobalLogContext, Version=3.0.0.0, Culture=neutral, PublicKeyToken=24c2f752a8e58a10, processorArchitecture=MSIL">
<HintPath>..\packages\Serilog.Enrichers.GlobalLogContext.3.0.0\lib\net45\Serilog.Enrichers.GlobalLogContext.dll</HintPath>
</Reference>
<Reference Include="Serilog.Exceptions, Version=8.0.0.0, Culture=neutral, PublicKeyToken=fc5550082a9c642c, processorArchitecture=MSIL">
<HintPath>..\packages\Serilog.Exceptions.8.4.0\lib\net472\Serilog.Exceptions.dll</HintPath>
</Reference>
<Reference Include="Serilog.Formatting.Compact, Version=1.1.0.0, Culture=neutral, PublicKeyToken=24c2f752a8e58a10, processorArchitecture=MSIL">
<HintPath>..\packages\Serilog.Formatting.Compact.1.1.0\lib\net452\Serilog.Formatting.Compact.dll</HintPath>
</Reference>
<Reference Include="Serilog.Sinks.Console, Version=4.1.0.0, Culture=neutral, PublicKeyToken=24c2f752a8e58a10, processorArchitecture=MSIL">
<HintPath>..\packages\Serilog.Sinks.Console.4.1.0\lib\net45\Serilog.Sinks.Console.dll</HintPath>
</Reference>
<Reference Include="Serilog.Sinks.File, Version=5.0.0.0, Culture=neutral, PublicKeyToken=24c2f752a8e58a10, processorArchitecture=MSIL">
<HintPath>..\packages\Serilog.Sinks.File.5.0.0\lib\net45\Serilog.Sinks.File.dll</HintPath>
</Reference>
<Reference Include="Serilog.Sinks.PeriodicBatching, Version=3.0.0.0, Culture=neutral, PublicKeyToken=24c2f752a8e58a10, processorArchitecture=MSIL">
<HintPath>..\packages\Serilog.Sinks.PeriodicBatching.3.1.0\lib\net45\Serilog.Sinks.PeriodicBatching.dll</HintPath>
</Reference>
<Reference Include="Serilog.Sinks.Seq, Version=5.2.2.0, Culture=neutral, PublicKeyToken=24c2f752a8e58a10, processorArchitecture=MSIL">
<HintPath>..\packages\Serilog.Sinks.Seq.5.2.2\lib\net45\Serilog.Sinks.Seq.dll</HintPath>
</Reference>
<Reference Include="Speckle.Newtonsoft.Json, Version=11.0.0.0, Culture=neutral, processorArchitecture=MSIL">
<HintPath>..\packages\Speckle.Newtonsoft.Json.13.0.2\lib\net45\Speckle.Newtonsoft.Json.dll</HintPath>
</Reference>
<Reference Include="SpeckleCore2, Version=2.14.2.10781, Culture=neutral, processorArchitecture=MSIL">
<HintPath>..\packages\Speckle.Core.2.14.2\lib\netstandard2.0\SpeckleCore2.dll</HintPath>
</Reference>
<Reference Include="SQLitePCLRaw.batteries_v2, Version=2.1.4.1835, Culture=neutral, PublicKeyToken=8226ea5df37bcae9, processorArchitecture=MSIL">
<HintPath>..\packages\SQLitePCLRaw.bundle_e_sqlite3.2.1.4\lib\net461\SQLitePCLRaw.batteries_v2.dll</HintPath>
</Reference>
<Reference Include="SQLitePCLRaw.core, Version=2.1.4.1835, Culture=neutral, PublicKeyToken=1488e028ca7ab535, processorArchitecture=MSIL">
<HintPath>..\packages\SQLitePCLRaw.core.2.1.4\lib\netstandard2.0\SQLitePCLRaw.core.dll</HintPath>
</Reference>
<Reference Include="SQLitePCLRaw.provider.dynamic_cdecl, Version=2.1.4.1835, Culture=neutral, PublicKeyToken=b68184102cba0b3b, processorArchitecture=MSIL">
<HintPath>..\packages\SQLitePCLRaw.provider.dynamic_cdecl.2.1.4\lib\netstandard2.0\SQLitePCLRaw.provider.dynamic_cdecl.dll</HintPath>
</Reference>
<Reference Include="System" />
<Reference Include="System.Buffers, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51, processorArchitecture=MSIL">
<HintPath>..\packages\System.Buffers.4.5.1\lib\net461\System.Buffers.dll</HintPath>
</Reference>
<Reference Include="System.Collections.Immutable, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=MSIL">
<HintPath>..\packages\System.Collections.Immutable.5.0.0\lib\net461\System.Collections.Immutable.dll</HintPath>
</Reference>
<Reference Include="System.Core" />
<Reference Include="System.Memory, Version=4.0.1.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51, processorArchitecture=MSIL">
<HintPath>..\packages\System.Memory.4.5.4\lib\net461\System.Memory.dll</HintPath>
</Reference>
<Reference Include="System.Net.WebSockets.Client.Managed, Version=1.0.22.0, Culture=neutral, processorArchitecture=MSIL">
<HintPath>..\packages\System.Net.WebSockets.Client.Managed.1.0.22\lib\net45\System.Net.WebSockets.Client.Managed.dll</HintPath>
</Reference>
<Reference Include="System.Numerics" />
<Reference Include="System.Numerics.Vectors, Version=4.1.4.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=MSIL">
<HintPath>..\packages\System.Numerics.Vectors.4.5.0\lib\net46\System.Numerics.Vectors.dll</HintPath>
</Reference>
<Reference Include="System.Reactive, Version=5.0.0.0, Culture=neutral, PublicKeyToken=94bc3704cddfc263, processorArchitecture=MSIL">
<HintPath>..\packages\System.Reactive.5.0.0\lib\net472\System.Reactive.dll</HintPath>
</Reference>
<Reference Include="System.Reflection.Metadata, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=MSIL">
<HintPath>..\packages\System.Reflection.Metadata.5.0.0\lib\net461\System.Reflection.Metadata.dll</HintPath>
</Reference>
<Reference Include="System.Runtime.CompilerServices.Unsafe, Version=5.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=MSIL">
<HintPath>..\packages\System.Runtime.CompilerServices.Unsafe.5.0.0\lib\net45\System.Runtime.CompilerServices.Unsafe.dll</HintPath>
</Reference>
<Reference Include="System.Runtime.InteropServices.RuntimeInformation, Version=4.0.1.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=MSIL">
<HintPath>..\packages\System.Runtime.InteropServices.RuntimeInformation.4.3.0\lib\net45\System.Runtime.InteropServices.RuntimeInformation.dll</HintPath>
<Private>True</Private>
</Reference>
<Reference Include="System.Text.Encodings.Web, Version=5.0.0.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51, processorArchitecture=MSIL">
<HintPath>..\packages\System.Text.Encodings.Web.5.0.1\lib\net461\System.Text.Encodings.Web.dll</HintPath>
</Reference>
<Reference Include="System.Text.Json, Version=5.0.0.2, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51, processorArchitecture=MSIL">
<HintPath>..\packages\System.Text.Json.5.0.2\lib\net461\System.Text.Json.dll</HintPath>
</Reference>
<Reference Include="System.Threading.Tasks.Extensions, Version=4.2.0.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51, processorArchitecture=MSIL">
<HintPath>..\packages\System.Threading.Tasks.Extensions.4.5.4\lib\net461\System.Threading.Tasks.Extensions.dll</HintPath>
</Reference>
<Reference Include="System.ValueTuple, Version=4.0.3.0, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51, processorArchitecture=MSIL">
<HintPath>..\packages\System.ValueTuple.4.5.0\lib\net47\System.ValueTuple.dll</HintPath>
</Reference>
<Reference Include="System.Windows" />
<Reference Include="System.Windows.Forms" />
<Reference Include="System.Xml.Linq" />
<Reference Include="System.Data.DataSetExtensions" />
<Reference Include="Microsoft.CSharp" />
<Reference Include="System.Data" />
<Reference Include="System.Net.Http" />
<Reference Include="System.Xml" />
<Reference Include="WindowsBase" />
</ItemGroup>
<ItemGroup>
<Compile Include="Program.cs" />
<Compile Include="Properties\AssemblyInfo.cs" />
</ItemGroup>
<ItemGroup>
<None Include="App.config" />
<None Include="packages.config" />
</ItemGroup>
<Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
<Import Project="..\packages\Sentry.3.29.0\build\Sentry.targets" Condition="Exists('..\packages\Sentry.3.29.0\build\Sentry.targets')" />
<Target Name="EnsureNuGetPackageBuildImports" BeforeTargets="PrepareForBuild">
<PropertyGroup>
<ErrorText>This project references NuGet package(s) that are missing on this computer. Use NuGet Package Restore to download them. For more information, see http://go.microsoft.com/fwlink/?LinkID=322105. The missing file is {0}.</ErrorText>
</PropertyGroup>
<Error Condition="!Exists('..\packages\Sentry.3.29.0\build\Sentry.targets')" Text="$([System.String]::Format('$(ErrorText)', '..\packages\Sentry.3.29.0\build\Sentry.targets'))" />
</Target>
</Project>
Could you try to use an SDK style project instead?
(maybe a bit outdated)
Hi @imanwarsame!
We’ve had a look at this and our recommendation would be to fully migrate your CSPROJ file to the new “SDK-style syntax”.
If you want to try something “less dramatic”: you’re also using the old packages.config instead of using PackageReferences, which is the current default in project-style syntax anyway
But you could try doing that first see if it solves the issue.
Thanks all, I created a NET core project then changed the framework to net48 to use the SDK style. Still not working unfortunately. I’ve shared the repo here (GitHub - imanwarsame/SpeckleNETFR)
I think you’re missing the platformTarget still ![]()
It’s working now, thanks all so much!
