Dear Support,
I’m encountering a server error when uploading about 100 models via the Revit plugin. Our server, version 2.16.0, is deployed with yarn dev. The PostgreSQL database is set up using the Docker configuration provided in the source code.
server logs:
[server] ERROR: Upload error. {"req":{"id":"bef2b7c0-f035-47ef-adf3-723733a5fb4b","method":"POST","path":"/objects/d7645a3083","headers":{"x-request-id":"bef2b7c0-f035-47ef-adf3-723733a5fb4b","content-type":"multipart/form-data; boundary=\"a9a7f9b9-09d9-4643-8132-88db1d8a829b\"","host":"10.5.56.19:3000","content-length":"38124","accept-encoding":"gzip"}},"authContext":{"auth":true,"userId":"f9786e8e7d","role":"server:admin","scopes":["streams:read","streams:write","profile:read","profile:email","users:read","users:invite"]},"userId":"f9786e8e7d","streamId":"d7645a3083"}
9|sp_server | [server] err: {
9|sp_server | [server] "type": "DatabaseError",
9|sp_server | [server] "message": "insert into \"object_children_closure\" (\"child\", \"minDepth\", \"parent\", \"streamId\") values ($1, $2, $3, $4), ($5, $6, $7, $8), ($9, $10, $11, $12), ($13, $14, $15, $16), ($17, $18, $19, $20), ($21, $22, $23, $24), ($25, $26, $27, $28), ($29, $30, $31, $32), ($33, $34, $35, $36), ($37, $38, $39, $40), ($41, $42, $43, $44), ($45, $46, $47, $48), ($49, $50, $51, $52), ($53, $54, $55, $56), ($57, $58, $59, $60), ($61, $62, $63, $64), ($65, $66, $67, $68), ($69, $70, $71, $72), ($73, $74, $75, $76), ($77, $78, $79, $80), ($81, $82, $83, $84), ($85, $86, $87, $88), ($89, $90, $91, $92), ($93, $94, $95, $96), ($97, $98, $99, $100), ($101, $102, $103, $104), ($105, $106, $107, $108), ($109, $110, $111, $112), ($113, $114, $115, $116), ($117, $118, $119, $120), ($121, $122, $123, $124), ($125, $126, $127, $128), ($129, $130, $131, $132), ($133, $134, $135, $136), ($137, $138, $139, $140), ($141, $142, $143, $144), ($145, $146, $147, $148), ($149, $150, $151, $152), ($153, $154, $155, $156), ($157, $158, $159, $160), ($161, $162, $163, $164), ($165, $166, $167, $168), ($169, $170, $171, $172), ($173, $174, $175, $176) on conflict do nothing - unexpected data beyond EOF in block 84700 of relation base/16384/188088",
9|sp_server | [server] "stack":
9|sp_server | [server] error: insert into "object_children_closure" ("child", "minDepth", "parent", "streamId") values ($1, $2, $3, $4), ($5, $6, $7, $8), ($9, $10, $11, $12), ($13, $14, $15, $16), ($17, $18, $19, $20), ($21, $22, $23, $24), ($25, $26, $27, $28), ($29, $30, $31, $32), ($33, $34, $35, $36), ($37, $38, $39, $40), ($41, $42, $43, $44), ($45, $46, $47, $48), ($49, $50, $51, $52), ($53, $54, $55, $56), ($57, $58, $59, $60), ($61, $62, $63, $64), ($65, $66, $67, $68), ($69, $70, $71, $72), ($73, $74, $75, $76), ($77, $78, $79, $80), ($81, $82, $83, $84), ($85, $86, $87, $88), ($89, $90, $91, $92), ($93, $94, $95, $96), ($97, $98, $99, $100), ($101, $102, $103, $104), ($105, $106, $107, $108), ($109, $110, $111, $112), ($113, $114, $115, $116), ($117, $118, $119, $120), ($121, $122, $123, $124), ($125, $126, $127, $128), ($129, $130, $131, $132), ($133, $134, $135, $136), ($137, $138, $139, $140), ($141, $142, $143, $144), ($145, $146, $147, $148), ($149, $150, $151, $152), ($153, $154, $155, $156), ($157, $158, $159, $160), ($161, $162, $163, $164), ($165, $166, $167, $168), ($169, $170, $171, $172), ($173, $174, $175, $176) on conflict do nothing - unexpected data beyond EOF in block 84700 of relation base/16384/188088
9|sp_server | [server] at Parser.parseErrorMessage (/home/release_2.17.3/node_modules/pg-protocol/dist/parser.js:287:98)
9|sp_server | [server] at Parser.handlePacket (/home/release_2.17.3/node_modules/pg-protocol/dist/parser.js:126:29)
9|sp_server | [server] at Parser.parse (/home/release_2.17.3/node_modules/pg-protocol/dist/parser.js:39:38)
9|sp_server | [server] at Socket.<anonymous> (/home/release_2.17.3/node_modules/pg-protocol/dist/index.js:11:42)
9|sp_server | [server] at Socket.emit (node:events:514:28)
9|sp_server | [server] at Socket.emit (node:domain:489:12)
9|sp_server | [server] at addChunk (node:internal/streams/readable:324:12)
9|sp_server | [server] at readableAddChunk (node:internal/streams/readable:297:9)
9|sp_server | [server] at Readable.push (node:internal/streams/readable:234:10)
9|sp_server | [server] at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
9|sp_server | [server] "length": 220,
9|sp_server | [server] "name": "error",
9|sp_server | [server] "severity": "ERROR",
9|sp_server | [server] "code": "XX000",
9|sp_server | [server] "hint": "This has been seen to occur with buggy kernels; consider updating your system.",
9|sp_server | [server] "file": "bufmgr.c",
9|sp_server | [server] "line": "1997",
9|sp_server | [server] "routine": "ExtendBufferedRelShared"
9|sp_server | [server] }
