Issue with AutoCAD Connector: Missing Layer Parameter and Zero Area for Polyline
Hi everyone,
I’ve encountered a problem while using the Speckle AutoCAD Connector. When I send a polyline from AutoCAD to Speckle, the following issues arise:
  1. The polyline lacks the “Layer” parameter in its properties.
  2. The “Area” value for the polyline is reported as 0.
I’ve double-checked the polyline in AutoCAD, and everything seems correct there. The layer is assigned, and the polyline is closed (so it should have a valid area).
Has anyone faced similar issues? Is this behavior expected, or am I missing a setting or step during the sending process? Any help would be greatly appreciated!
Thanks in advance.
