I’m having some trouble with consistently uploading documents from Rhino 8. I’m using the 3.3.0 release of the Rhino connector currently but I’ve been experiencing a similar problem for a few weeks.
I’ve only found this issue with larger documents (50-200 mb). When I simply upload a single cube or something similarly small, everything works fine. The weird part is that the same document will upload just fine in the morning and then will fail when I upload again later in the day.
FWIW for server stuff, I am based in Albany, New York, USA.
I am happy to provide the document & speckle link privately.
Objective: Upload from Rhino 8 using the desktop connector.
Issue: When uploading geometry, the connector interface seems to hang on the “Serializing” step. Then proceeds to the “Uploading” step where it shows a much lower upload speed than I would expect for our connection (<250 kb/s). Then it throws “Error while sending”.
Example: I open the document in Rhino 8, select all objects and publish the selection to its respective speckle model.
Logs: SpeckleCoreLog20250604.txt (14.9 KB)
