Hi Speckle Community! I encountered an error when using Blender 3.6 with the Speckle Blender Connector 2.20.1. The error says “IndexError: list index out of range” when trying to execute a command in the bpy_speckle/operators/streams.py script. I’ve verified my active user settings, reinstalled the connector, and updated both Blender and Speckle, but the issue persists. Any suggestions on how to resolve this? Appreciate any help!
Hi @bima_deaziz
Please can you try using 2.20.0 and see if you can reproduce the same problem?
I’ve just spotted a problem with sending introduced today in 2.20.1
I’m just deploying a fix in 2.20.2. But the error message your seeing looks different from what I was seeing, so I would also suggest that you open the console (Window → Toggle System Console) and see if there are any errors or warnings there.
I tried using version 2.20.0, and it worked! Thank you for the recommendation—it solved the issue. I appreciate the help!
Glad to hear you have something working now.
Thank you for bringing the issue to light.
If you do get time to test 2.20.2, please let me know the result as the prior issue with 2.20.1 should now be resolved.
