hello speckle community,
I was trying to replicate the extract categories from revit with my model, following the video posted on youtube. The issue is that even though i could get the visual element on my sheet; When i try to place the slicer nearby which displays the extracted category from my revit model, The 3D visual and my slicer are not interacting. When I click on ANY element in the model it’s just displaying the first category from the slicer list for everything. Also when I select categories from slicer, that’s not reflected in the 3D visual. Please help me to figure out what’s wrong with my file.
Hey @SHALINI,
Welcome to Speckle!
I checked the model and something is not right for sure.
- What Revit Version are you using?
- What Speckle Revit Connector version are you using?
I see that you are using the old WebApp.
I will recommend you switching to the new version. https://app.speckle.systems/
After you login to the new WebApp, go and setup you account in the Speckle Manager.
After you click Add Account, add the new Server URL: https://app.speckle.systems/
Now let´s try and send the model again to the new WebApp.
First make sure that you are using a Speckle Connector Version 2.19.0 or 2.19.1. You can see that on your Speckle Manager.
After you update the Speckle Connector Version, open Revit and create a new stream in the new WebApp. Make sure you select the https://app.speckle.systems/.
In addition to what @Nikos suggested, which version of the 3D Visual are you using? I suggest using version 2.18 as we received reports of version 2.19 not interacting with other visuals in the dashboard.
Release 2.18.0 · specklesystems/speckle-powerbi-visuals (github.com)
