Ifc Upload issues
Hello friends!
I am having som upload issues.
When im trying to upload an architectural ifc it seems to load, but it just ends up spinning on “uploading new version”. I have tried to delete the model and reuploading it, but it still ends up on “uploading new version”.
Eiksveien 73 | Speckle
I have another project where i am getting the same issue.
I have tried to reduce the file size, but i have managed to upload bigger files. So im not certain that the file size is the issue.
im using the drag and drop feature for uploading.
The end goal is to visualize the models in power bi
All help would be greatly appreciated
  • Logs: If the issue regards our desktop connectors, please share the relevant logs you find under:
    Speckle Logs.zip (78.7 KB)
Hi @Thorras
We’re working to improve our IFC parsing service, in the meantime, could you please upload these IFCs in the google drive folder I just shared with you?
What application do they come from?
I will! Thanks a lot friend.
The one i uploaded comes out of Archicad
The other one is from SimpleBIM
You guys rule! <3
"Eiksveien 73 " = Archciad
“Lysaker Torg” = Simplebim
Hello again freinds! It seems to work if i push it through using the blender connector. Its a bit annoying with having to use another “step”. But it gets the job done, at least for now.
Thanks for making it possible to have mulltiple ways of using you platform and achieving what we want!
