If the connector still uses HTTPS and port 443
Hi! Please help me. I don’t understand it, but when I try to connect to my personal server, it gives me an error with the 443 protocol. Blender 3d. Although I specified http://xx.xx.xxx.xx in the URL.
In the server settings, I need to remove the redirect (it’s easier) Or in the connector settings?
If the connector still uses HTTPS and port 443, you need to enter the URL with the http:// protocol and the desired port when adding an account or stream in Speckle Connector. If the connector still uses HTTPS and port 443, it is due to internal Speckle settings or security policies that are not always available to change through the UI. In this case, it is worth checking the configuration files or contacting Speckle support.
Thanks for the report!
This sounds like it could be a bug in the Blender Connector not checking if the server url is https or http.
I’ll investigate…
Thanks, if this is a bug - I hope there will be a fix soon. God bless you!
Hello dear developers! Please tell me, are there any fixes already? Maybe they’ve made changes and I need to download a new installation file or wait for a new version update?
Hi @hanter282,
The fix is not yet released.
I’ll let you know when it is released.
