I need help with Surface from Rhino to Revit
CONVERSION ERRORS
Gap between current and previous co-edges in BRepBuilder::addCoEdgeInternal_(): check that edge-curve orientations and co-edge flipped-flags are correct.
Parameter name: edgeId
Hi @eAbzu,
Welcome to the community! Feel free to Introduce yourself :person_gesturing_ok: to the community if you want to! :smiley:
We are currently improving our Brep conversions for Revit. If you can share the files/commit causing the issue, we can take a look at it and make any improvements on our end if we can or come with a workaround for you.
