I own all my projects and I can’t change them to public for viewing in powerbi. The message “Project update failed. An unexpected issue occurred” always appears.
Hi @PedroToctao
Sorry to hear that you’re experiencing this issue, I’ll try to investigate.
Can you please provide the ID of the project (you can find it in the url), or your user ID (you can find it in the settings, profile page)? Can you confirm that you are using https://app.speckle.systems, or confirm the url of the server you are using?
Iain
b522eb19c9
Thank you @PedroToctao
I’m unable to find any relevant logs from the server. I’m wondering if it’s a frontend related issue?
Are you able to open Developer Tools, and provide a screenshot of the Console tab when the error occurs? (It’s best to refresh the page, then immediately undertake the failing action, then capture the screenshot).
Hey @PedroToctao ,
Can you try setting it to Link Shareable and check if it works. For Power BI, setting visibility to Link Shareable is enough.
Thanks; would you be able to please try the same again showing the ‘Console’ tab? - (to be found near the top of the DevTools window).
