It’d be great to look up a stream by a more human readable path in order to allow end users to easily sense check that the data they’re pulling is from the right source:
This could be done with some magic behind the scenes that looks up the stream names from the avaliable ids and returns the real underlying stream.
Good idea. Currently, it is possible to have multiple projects with the same name. That’s why we’re identifying them by giving them a unique id. I’ll let @dimitrie give you a detailed answer if its possible to implement.
