Hi, I have been following the tutorial about the creation of revit geometry from grasshopper but I have the following problem:
“1. Solution exception:Cannot understand what unit metri is.”
Can someone help me?
Thanks.
Thanks.
Hi @nic_man,
Let me start by welcoming you to our community! If you haven’t already, feel free to Introduce yourself 🙆 to everyone hanging around here
Now, onto the problem. It seems like you’re getting the units in a “localised” form, so I’m assuming you have your Rhino in a language that is not english?
I’d have to check this out with a bit more detail, but the fastest way to fix this on your side (I’m hoping) is to modify your Rhino installed language. I’ll also ping @teocomi, since I recall having this issue (or a similar one) in the past…
To change the language you can follow this post from the Rhino peeps:
We’ll try to fix this on our side for the upcoming release 2.8
, but if you’re able to check the language change, we’d love to hear if that did the trick!
Thanks for reporting this!!
Thank you @AlanRynne, the problem with units is now solved.
But unfortunately I have a problem with exporting.
I want to speckle a series of windows for Revit. To do this I am using Speckle for Revit components. In detail I used this script:
In both the speckle preview and in Revit, some windows are not planar:
Thanks for the support.
Hey @nic_man ,
This is quite weird! Can you share that definition with us so we can debug a bit?
In the meantime you could also try our latest and greatest DXF import setting (codenamed “Sexy Meshes”): Revit | Speckle Docs
