Hi there,
I am retrieving client owner IDs from a Project through the API, and I would like to get their related user information (name, surname, company name) based on those IDs.
I have checked the UserSearch.vue component which seems to do it, and then noticed that I do not have access to /accounts/ (see below)
Any hints?
Paul
Hey Paul!
There’s actually an api endpoint for this; it though needs always an authorization token. If you’re working in speckle admin, there’s already a method to get that info in the store. It looks like this:
getUser( context, payload ) {
return new Promise( ( resolve, reject ) => {
let found = context.state.users.find( u => u._id === payload._id )
if ( found ) return resolve( found )
Axios.get( `accounts/${payload._id}` )
.then( res => {
if ( context.state.user._id === payload._id ) res.data.resource.surname += ' (that is you!)'
context.commit( 'ADD_USER', res.data.resource )
return resolve( res.data.resource )
.catch( err => {
return reject( err )
Hope this helps & thanks for asking on the forum, so others can pick up later!
Thanks, solved it!
some more text to make this message > 20 chars
