Hey everyone,
I am very new to speckle and was struggling to apply frame loads to a truss model I developed. The model geometry works fine but the load component seems to be not working. I am importing to Etabs 2021 but have also tried importing to Etabs 2018, unfortunately it didn’t work in either versions.
trancas.gh (55.4 KB)
Hey @Aprasai,
Welcome to Speckle and the community! Feel free to introduce yourself to the rest of the community here.
Thanks for posting your question! We’ve made some updates to get this working better (see below for a little preview ).
Once this is available for you to test I will let you know (should be this next week). I will also provide you with a little GH script showcasing the best way to approach the frame load application. Stay tuned!
Hey @Aprasai,
Good news! v2.22.2
is out with the enhancements as previewed above.
Update all installed connector versions to the latest please and give that a go. To get loads to work effectively please ensure the following:
Grasshopper Definition:
- Give all your
CSIElement1D
’s aname
attribute. This way we can know which frame elements are which and that we have a correct load application
- Define your load component in Grasshopper similarly to below. The
name
of theLoadCase
should match a predefined load pattern in your ETABS model. The positions are relative positions (0 = start, 1 = end). For theelements
, provide theCSIElement1D
you defined.
- Order of information:
LoadBeam
should be the last component you wire into the send component.
ETABS Definition:
- As mentioned, make sure that the load pattern is predefined in ETABS before trying to receive.
The sample script is also attached below. Give me a shout if you have and difficulties!
bars to etabs.gh (26.1 KB)
