I just released 2.1.5-beta, which contains some minor fixes that (i hope) will allow the Object Management nodes to load properly and without any exceptions thrown.
It should still throw the error on the other nodes mentioned (including Schema Builder). If you guys could confirm this works properly, I can get the fix for all the nodes released today
I’ve installed 2.1.5 (I didn’t update the manager to 2.0.25, I kept it on 2.0.22). After a bunch of Rhino reboots I got the error again.
You are right about the not working CreateSpeckleObject and ExpandSpeckleObject nodes. Even all GH nodes (tried all Speckle 2.0 nodes and several standard GH ones, like point, panel, etc.) throw this Grasshopper breakpoint error when I place one on the canvas.
If you find it helpful, we could have a 1on1 call about it next week.
Oh dear…did I make it worse? it looks like I only managed to defer the problem to a later point in the program. I actually just moved some logic from the startup to when it’s added on a document.
The fact that other nodes throw errors when placed in the canvas is super weird… That shouldn’t really affect other nodes at all I’m confused… I’ll keep digging at it but it that 1on1 would definitely be helpful just to see it happening live.
Anyway, I can see you still get the “loading errors” on startup for all the Object management nodes, so something else is going on here too…
I’ll keep posting here my findings (or lack thereof).
Just bugging you guys again to keep you updated with the progress of this. I just published version 2.1.6-beta of the Grasshopper connector which partially fixes the issue (for the third time…) except for the nodes shown below:
Could you install the latest version and check 2 things?
If the errors you get when it happens are the same as the screenshot above. If anything differs could you let me know which?
Once the document is loaded, you should be able to instantiate new ObjectManagement nodes but I am uncertain if they will work. Could you confirm if they work? If not, what’s the error you get?
Thanks for the patience! Hopefully this will do the trick and we can finally get it behind us
So it appears I also need to do some minor fixes on the KitManager to prevent it from happening. I’ll ping you back here once it’s published and hopefully you’ll never see this error again
Version 2.1.7-beta of the Grasshopper connector should go live any minute now. My expectation is that it should go back to working 100% of the time, but I still have a doubt on the KitManager fix I just pushed to wrap things up.
Please, let me know if you have any issues with that, such as No default kit was found in this machine or any other error.
I won’t celebrate until you guys can confirm you no longer experience this
