GraphQL Error on server initial setup
Hi there!
So, I’ve been playing around with the current version of the 2.0 server, trying to get it up and running.
I managed to build and run the master branch correctly but it seems I hit a bump in the road!
I followed the instructions in the main readme.md (postgres db, redis… etc). But when trying to setup the server at http://localhost:3000/setup I always get the following error:
I’m not sure if this is a misconfiguration on my behalf. I also tried registering directly and that did work, allowing me access to the /explorer route with the GraphQL Explorer.
It appears the user is granted the server:admin role. Once logged in, if I try to access the /setup route, I automatically get sent to step 2, but I am unable to finalise the process due to “not having the required privileges” (there is also a typo in the error message :sweat_smile:)
Any idea what is happening here? Have you encountered this before?
Thanks for checking this out Alan!
While we investigate further, could you also try running all the tests in the server?
That might help pinpoint what’s going on…
I just ran the test:server script and all tests pass successfully.
I tried running the dev:server:test script and I get the following info message about not having completed the setup:
Hi @AlanRynne! Kindly ignore the setup app - especially in development mode. It’s not ready, and it’s not fully scoped yet. It was just a tryout :slight_smile: (that’s causing complications!!!)
And yes, the first user who registers on the server becomes an admin, just like in 1.0 - we might get rid of that behaviour later.
