Am getting these error messages while uploading a Revit file to Speckle. These are plumbing elements and Section box that cuts the model to view inside. Are these not supported in Speckle?
CONVERSION ERRORS
Skipped not supported type: Autodesk.Revit.DB.Plumbing.PipingSystem, name: Sanitary 2, id: 45b16ebb-8d2a-4e87-a745-a810043e4bf6-00073245
Skipped not supported type: Autodesk.Revit.DB.Plumbing.PipingSystem, name: Sanitary 5, id: 45b16ebb-8d2a-4e87-a745-a810043e4bf6-00073248
Skipped not supported type: Autodesk.Revit.DB.Plumbing.PipingSystem, name: Domestic Cold Water 4, id: 45b16ebb-8d2a-4e87-a745-a810043e4bf6-0007324b
Skipped not supported type: Autodesk.Revit.DB.Plumbing.PipingSystem, name: Domestic Hot Water 3, id: 45b16ebb-8d2a-4e87-a745-a810043e4bf6-0007324d
Skipped not supported type: Autodesk.Revit.DB.Plumbing.PipingSystem, name: Domestic Hot Water 4, id: 45b16ebb-8d2a-4e87-a745-a810043e4bf6-0007324e
Skipped not supported type: Autodesk.Revit.DB.Plumbing.PipingSystem, name: Domestic Cold Water 6, id: 45b16ebb-8d2a-4e87-a745-a810043e4bf6-0007324f
Skipped not supported type: Autodesk.Revit.DB.Plumbing.PipingSystem, name: Domestic Cold Water 7, id: 45b16ebb-8d2a-4e87-a745-a810043e4bf6-00073252
