Floors not Showing Up as "Floors" on dropdown menu, only "Direct Shape"
Context:
I followed your tutorial to import elements as direct objects from Rhino to Revit. The model exists in Revit; however, when I send back to Rhino to assign each element a family (ie: floor plates), it doesn’t allow me to select “Floors” under “Revit Element to Map.”
Hey @bchin411 ,
Welcome to the forum!
Revit Floors can only be created from planar Rhino surfaces, if yours is not planar you can created it as a DirectShape with the Floor category.
If your geometry is already a planar surfect, please send it to us via DM so we can check what’s up!
