I wanted to define an onboarding project for the colleagues to start with FE2. I defined the project of our deployment in the docker-compose.yml. Somehow this was not used for a new colleague logging in.
# URL of a project on any FE2 speckle server that will be pulled in and used as the onboarding stream
ONBOARDING_STREAM_URL: 'https://our-deployment.com/projects/projectid'
# Increase this value to re-sync the onboarding stream
ONBOARDING_STREAM_CACHE_BUST_NUMBER: 1
Is there anything else required to be specified?
Had a nice tiny boring project defined for it, nothing as fancy as you guys have
Can you share the full URL to the onboarding stream? It has to be a publicly accessible stream for it to work (as in - unauthenticated users must be able to access it).
Also - do you see anything in the server logs related to the onboarding stream/project?
Hey @fabians,
thanks for your support on this. I will send you a PM at the end of the day with the infos (Link and Log). It is a publicly accessible link from our deployment.
Best,
Alex
