Failing to send layer from QGIS (large Geojson with +120k entities)
I’m trying to send objects (point entities) from a Geojson loaded in QGIS.
I’m getting a 400 error (see screenshot above)
The GeoJSON is available here: Signalisation permanente — SNCF Open Data
https://ressources.data.sncf.com/api/explore/v2.1/catalog/datasets/signalisation-permanente/exports/geojson?lang=fr&timezone=Europe%2FParis
Any clue what could go wrong here?
Hi @pauldotnet - were you sending to speckle.xyz?
If so, could you please share the url of the stream you were sending to?
Hey @iainsproat, thanks for the fast answer
Here it is: Speckle
There is some line network but the data I’ve attempted to send is a list of points which didn’t commit.
Thanks for sharing this, we’ve been able to identify the problem - the connector was sending data in batches to the server and one of those batches exceeded the maximum size limit imposed by the server.
I’ll coordinate with @Kateryna on how best to resolve this for you.
Thank you!
Actually, I’ve also tried to send the same data from the Excel Connector and it failed as well to send everything. A small portion of it worked
Branch | Speckle
Hi @pauldotnet - as an update, we’ve made a fix to the server which we’re currently testing. We’ll try and roll this out in the new few days/weeks.
